Inventor Forum
Constrain cylinder edge to angle surface
12 REPLIES 12
Message 1 of 13
cadcamm99
3049 Views, 12 Replies
I have a cylinder part that I want to constrain to another cylinder part that has an angled surface but I can't seem to do it. I can't seem to pick the parts edge or a quadrant point to mate with the angle surface. Is there a way to make this happen?
12 REPLIES 12
Message 2 of 13
admaiora
in reply to: cadcamm99
Can you attach the 2 parts?
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 3 of 13
JDMather
The Insert constraint should work.
Message 4 of 13
wimann
JD is right, an insert constraint would work. But I guess if you're set on using a centerline mate and another constraint, you could use the top surface of the normal clyinder to the centerpoint of the geometric circle that exists on the bottom side of the sloped cylinder.
See attached for both.
-Will Mann
Inventor Professional 2020
Vault Professional 2020
AutoCAD Mechanical 2020
Message 5 of 13
Hi cadcamm99,
In addition to the other replies, you might try something like this:
http://inventortrenches.blogspot.com/2011/06/assembly-challenge-mating-spherical.html
I hope this helps.
Curtis
Message 6 of 13
johnsonshiue
Hi! It is better to post the files here. It is possible the cone face may not be a true cone. If it is a spline face, I don't think Insert will work. You will need to create a loop-based workpoint to define the center and then create a workaxis based on the workpoint. It is hard to tell which is which just by looking at the images.
Thanks!
Software Test Engineer
Message 7 of 13
The link was exactly what I was looking for.  Except the distance moved is so small that it only shows 0.00000.  It moves but the distance is so small.  On my other assembly where the parts are larger this works fine.  Its like 0.00045.  Too bad I can't put a point on the circular edge.  It would make things much simpler.
Message 8 of 13
cadcamm99
in reply to: wimann
The insert constraint would only align the center points of the edges.   I want the edge to touch the drafted surface.
Message 9 of 13
JDMather
You can put a point on a circular edge, or even in space in imaginary location where a cylindrical edge would be at axis of hole.
Attach your file here for demonstration.
Message 10 of 13
JDMather
I'll wager that Insert constraint will work for me.
Attach your assembly here.
Message 11 of 13
JDMather
in reply to: JDMather
Message 12 of 13
cadcamm99
I got this to work.  I used the link from before.  But since I picked centerpoint to centerpoint, it did not register a distance. I had a plane at the bottom of the drafted part and used that instead and it registered a distance and it worked fine. now the edge touches the drafted surface.
Message 13 of 13
JDMather
You know the diameter of the cylinder.
Simply create a circle or line and Split the cone face (or spherical face in Curtis' example).  Now you have a perfect circle on the cone or sphere to use Insert.  No calculations needed.
