Inventor General
Active Member
Message 1 of 2 (210 Views)
Constrain component in a track
210 Views, 1 Replies
11-25-2012 08:25 AM
I'm trying to make a constraint allowing the dark smaller cylinder (1) to run in the copper track (2). I want the larger cylinder (3) to be able to rotate around its own axis, while everything is rotating around the Z axis. I've successfully constrained the parts so that all the parts can rotate around the Z-axis but when I constrain the smaller cylinder (1) with the tangent constraint with the track (2) the smaller cylinder is not able to move around on the face, it's just glued to the face. I hope that you have understood my problem, even though my explination might not be the best.
I want the smaller cylinder (1) to recognize the copper faces as solids (so that it can't intersect the surfaces), this would allow the proper movement.
I've attached an image of the parts.
Thanks!
*Expert Elite*
Message 2 of 2 (183 Views)
Re: Constrain component in a track
11-25-2012 10:23 AM in reply to: eric.vinjegaard
Use Transistional - not tangent constraint.
There is a chance Contact Sets might help.
If that doesn't work you will have to go into Environments>Dynamic Simulation.
Attach your assembly here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
