I'm not sure I would go with a i5 over an i7. I think the price of this computer is maybe even a little high.
My thoughts.
I would try to go for an i7 processor.
The amount of ram looks good.
I would try like crazy to go for Windows 7 64 bit over XP 64 bit. A giant improvement in my opinion
I would have a look at a GeForce card instead of the Quadro if using DirectX. A very high end gaming card will only set you back about $400.
Do you work off a network? If not, I would also consider going for an SSD or a 10,000 RMP HDD.
Go check out XI computers. I think you will find you can build a much higher end cad system there than what you are getting for your money.
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
