Hi.
I have really huge assemblys. I use Inventor 2014 Pro SP1 Up2.
I am looking for some kind of a really good computer.
I would appreciate your suggestions for a omputer recommendations for really large assemblies (over 5000 different parts)
What's more important? Ram? HDD? Graphics?
Thanks in advance. Any help is much appreciated!
RAM plays a very big part in Inventor. So lots and lots of ram. You should also get a pc with a really good graphics card.
Thank you both for the replies.
Based on your replies and some reasearch, here is the hardware I am thinking for the new computer:
- Intel Core i7 4770
- Motherboard Asus Z87-K
- Graphics Asus GT 640, PCI-E 2GB DDR3
- Memory Kingston DDR3 16GB 2400MHz
- SSD Kingston HyperX 240GB
- Case Cooler Master K280 + Power Cooler Master B-700W
- Windows 8.1
What would you change?
@marcocruz wrote:Thank you both for the replies.
- Windows 8.1
CPU / mobo / ram are very nearly what I've got at home, except I've got Z87 Pro, Corsair RAM and a Samsung 840 SSD. Works great.
I'd get something a little higher up than a 640 for your video card. Try and get something that ends in -50 or -60, at a minimum. 650/660/750/760, or higher. 6xx vs 7xx is MUCH less important than the difference between x40 and x70. (That said, I'm still running my 6 year old 512 MB ATI 4870's in that machine. They're definitely a bottleneck, but not too bad. GDDR5 and 256-bit memory pathway overcomes a few of the more egregious issues you'd expect. 🙂 )
Also, try and get Windows 7 if you can. 8 and 8.1 are a mess. I've seen lots of people have lots of problems with 8.1 when running Autodesk software. Moreso with 8.1 than 8, but 7 is still the best for now.
Rusty
Windows 8.1 is not yet compatible with Autodesk products. Windows 8 works perfectly. (I am running windows 8 and had no issues).
If you take windows 7 and want to upgrade at a later stage you will have to buy 8 again. and I am sure you dont want to upgrade your pc twice. So I would recommend windows 8 and later when Autodesk has fixed the 8.1 issues you can just upgrade your version which would be free
The specs for my last workstation are listed below. This unit is now about 16 months old. The only change would be to upgrade the graphics card to a GTX-780 card. Love the performance of the system.
@JoAnn_Hogan wrote:Windows 8.1 is not yet compatible with Autodesk products. Windows 8 works perfectly. (I am running windows 8 and had no issues).
The fix for Windows 8/8.1 will be called Windows 9, and it's most likely going to ship in 2015. Whether OP has 7 or 8 installed now, he'll still have to buy 9 if he wants to upgrade.
Windows 7 will continue to be supported for a very long time. I really wouldn't worry too much about the upgrade costs from 7 to whatever else.
Rusty
I'm somewhat curious - how much perceived or actual performance gains you are getting out of the RAID 0 drive setup?
I dont quite understand why windows will jump from Windows 8 to 9 in such a short period. Besides windows 8 will still be available so Autodesk will have to bring out a fix sometime. Windows 8 is fine. 8.1 is the one with the issues
@JoAnn_Hogan wrote:I dont quite understand why windows will jump from Windows 8 to 9 in such a short period. Besides windows 8 will still be available so Autodesk will have to bring out a fix sometime. Windows 8 is fine. 8.1 is the one with the issues
Microsoft is finally accepting that Windows 8 is absolute poison, when it comes to branding. Same thing happened with Vista. Vista was so poisonous that a lot of businesses skipped even over 7, and are STILL running XP today. It's even worse with 8 / 8.1.
The turnaround from Vista to 7 was only, what, 3 years? That's about the same time frame that's expected from 8 to 9. Given that Autodesk dropped support for Vista as quickly as they did - and maintained support for XP for as long as they did - I expect that Windows 7 will continue to be supported by Autodesk (and likely Microsloth as well) for a very long time, and Autodesk at least will very quickly push Windows 8/8.1 down the memory hole.
Rusty
@Nicolas.Bourquin wrote:All my apologize, I forgot this interesting link
Best Regards
Just out of curiosity, why does that link make reference to AGP slots? I'm fairly certain that any computer with an AGP slot is going to fail one or more of the minimum system requirements for pretty much any 2014 Autodesk product ...
Rusty
