Hi all,
After a bit of thought I’ve decided to do a write up on issues with item numbers in Inventor drawings. My reasons for this are that I want to know if there any ways to do what I want to do that I haven’t discovered, describe some current methods that some of you might find useful, and get support and/or criticism for a new feature that I am going to present.
As a draftsman with 4 years + experience with Inventor, I have come to know the program fairly well and regard it highly.
There is however one major flaw with the drawing environment: The inability (there are workarounds, which I will get to shortly) to attach an item number to component detail views that reference the BOM of their parent assembly.
This may seem trivial, but is a subject that keeps coming up, not just from Inventor users but also from other design office personnel, allocation staff and manufacturing workers.
I won’t rule out the possibility that this feature exists (if it does, please enlighten me!), but I would like to know why such an important feature has been omitted. Legal/copyright reasons? Marketing reasons? It’s not possible to program it that way? Not seen as important? In development?
Whatever the case, I will now discuss 3 workaround methods, followed by my own suggestion as to how I believe this feature could/should be included.
Method 1: iProperties Item Reference
Using this method, the item column and item bubbles reference an iProperty (such as Part Number or Stock Number) rather than the Item Number found in the BOM. A base view of an assembly is placed on a drawing, followed by base views of its parts. A parts list referencing the assembly is then created, and item balloons are attached to all parts on the assembly view and all component base views.
Advantages of this method include:
Disadvantages include:
Method 2: Component View Representations
In the assembly, a new view representation is created for each component, in which visibility for every other component is switched off. A base view of the assembly is placed on a drawing with the relevant view representation selected for each part detail.
Advantages:
Disadvantages:
Method 3: Weldment Detail
This method is similar to the view representation method, however the views are created automatically. It has the disadvantage that a weldment must be created for it to be of any use; as such it has no use for fastened assemblies that require component details.
These 3 methods all have their pros and cons, and really only appear to be workarounds for the problem at hand.
Now to my suggestion:
COMPONENT VIEWS
First, a standard base view of an assembly is placed on the drawing.
In the drawing environment, on the views panel of the drawing tab, there will be a button titled “Component Views”.
Pressing this button will bring up a prompt that says “select source view”.
The user then clicks on the base view on the assembly, and a dialogue box appears.
The box has a list of the assembly’s components, each next to a check box. The user then checks the required components, or checks “select all”.
The user then places each component view 1 by 1, selecting orientation as they go.
Item balloons can now be added to the component views; the number reflects the item number in the parts list of the parent view.
BOM data can also be added to the view label via “BOM Properties” in the drop down menu, and “Component Properties” references the iProperties of the component; Model Properties still allows the parent assembly to be referenced.
The component view can be turned into a standard base view by right clicking it and selecting “convert to base view”. I would also endorse the possibility of converting base views to component views.
I’m no expert on the programming side of things, but I don’t see why this isn’t possible; all the information is there, it seems like it’s a matter of getting it all in the one place.
Please let me know what you think about the component views idea. Preferably quote one of the following points
Thanks for reading, constructive criticism is greatly appreciated.
Solved by Curtis_Waguespack. Go to Solution.
Curtis,
I much enjoy and appreciate the rule you wrote to auto create view reps.
I do have one comment though.
Problem: After running the rule on the assembly and starting a drawing we need to add another part to the assembly. This issue is this new
part is now visible in each preious view rep. The work around is to make the unwanted part not visible. Is there a way this could be added to the rule?
This is the rule i am refering to :
'create a design view representation for each unique part in the assembly 'define current document Dim openDoc As Document openDoc = ThisDoc.Document 'set a reference to the assembly component definintion. 'this assumes an assembly document is open. Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition 'look at all of the components in the assembly Dim oCompDef As Inventor.ComponentDefinition = openDoc.ComponentDefinition 'define the first level components collection Dim oCompOcc As Inventor.ComponentOccurrence 'define view rep Dim oViewRep As DesignViewRepresentation 'define an arraylist to hold the list of view rep names Dim NameList As New ArrayList() 'Look at the view reps in the assembly For Each oViewRep In oAsmCompDef.RepresentationsManager.DesignViewRepresentations 'set the list of names to the array list NameList.add(oViewRep.Name) Next 'check for a Default view rep and create it if not found If Not NameList.Contains("Default") Then 'create Default view rep oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add("Default") oViewRep.ShowAll oViewRep.Activate End If 'zoom all ThisApplication.CommandManager.ControlDefinitions.Item("AppIsometricViewCmd").Execute 'look at all of the unique parts in the assembly For Each docFile In openDoc.AllReferencedDocuments If docFile.DocumentType = 12290 Then '12290 is the part document enumurator 'locate the last backslash position in the full file name Dim FNamePos As Long FNamePos = InStrRev(docFile.FullFileName, "\", -1) 'remove path from part file name Dim docFName As String docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos) 'remove extension from part file name ShortName = Left(docFName, Len(docFName) - 4) 'check to see if the arraylist contains the desired view rep If Not NameList.Contains(ShortName) Then 'create new View Rep oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add(ShortName) oViewRep.Activate oViewRep.Locked = False Else If NameList.Contains(ShortName) Then 'reference existing View Rep oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item(ShortName) oViewRep.Activate oViewRep.Locked = False End If 'look at all of the occurences For Each oCompOcc in oCompDef.Occurrences 'locate the colon position in the occurence name oCompOccPos = InStrRev(oCompOcc.Name, ":") 'set occurence name to everything left of the colon oOccName = Left(oCompOcc.Name, oCompOccPos -1) 'set visible if name matches first occurence If oCompOcc.Name = ShortName & ":1" Then oCompOcc.Visible = True ThisApplication.ActiveView.Update() Else oCompOcc.Visible = False ThisApplication.ActiveView.Update() End If Next End If 'lock view rep oViewRep.Locked = True Next 'set Default View Rep active
oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item("Default").activate
thanks a lot
Rick Laney
The code will work if you have checked the associative checkbox when creating a view.
Hi @petr.foltan,
see this version.
I hope this helps.
Curtis
'create a design view representation for each unique part in the assembly 'define current document Dim openDoc As Document openDoc = ThisDoc.Document 'set a reference to the assembly component definintion. 'this assumes an assembly document is open. Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition 'look at all of the components in the assembly Dim oCompDef As Inventor.ComponentDefinition = openDoc.ComponentDefinition 'define the first level components collection Dim oCompOcc As Inventor.ComponentOccurrence 'define view rep Dim oViewRep As DesignViewRepresentation 'define an arraylist to hold the list of view rep names Dim NameList As New ArrayList() 'Look at the view reps in the assembly For Each oViewRep In oAsmCompDef.RepresentationsManager.DesignViewRepresentations 'set the list of names to the array list NameList.Add(oViewRep.Name) Next 'check for a Default view rep and create it if not found If Not NameList.Contains("Default") Then 'create Default view rep oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add("Default") oViewRep.ShowAll oViewRep.Activate End If 'zoom all ThisApplication.CommandManager.ControlDefinitions.Item("AppIsometricViewCmd").Execute 'look at all of the unique parts in the assembly For Each docFile In openDoc.AllReferencedDocuments If docFile.DocumentType = 12290 Then '12290 is the part document enumurator 'locate the last backslash position in the full file name Dim FNamePos As Long FNamePos = InStrRev(docFile.FullFileName, "\", -1) 'remove path from part file name Dim docFName As String docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) -FNamePos) 'remove extension from part file name ShortName = Left(docFName, Len(docFName) -4) 'check to see if the arraylist contains the desired view rep If Not NameList.Contains(ShortName) Then 'create new View Rep oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add(ShortName) oViewRep.Activate oViewRep.Locked = False ElseIf NameList.Contains(ShortName) Then 'reference existing View Rep oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item(ShortName) oViewRep.Activate oViewRep.Locked = False End If 'look at all of the occurences For Each oCompOcc In oCompDef.Occurrences.AllLeafOccurrences 'locate the colon position in the occurence name oCompOccPos = InStrRev(oCompOcc.Name, ":") 'set occurence name to everything left of the colon oOccName = Left(oCompOcc.Name, oCompOccPos - 1) 'set visible if name matches first occurence If oCompOcc.Name = ShortName & ":1" Then oCompOcc.Visible = True ThisApplication.ActiveView.Update() Else oCompOcc.Visible = False ThisApplication.ActiveView.Update() End If Next End If 'lock view rep oViewRep.Locked = True Next 'set Default View Rep active oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item("Default").activate
Thank you from all of us.
What exactly does the "all leaf occurrences" do/change?
(Is that what's new? I copied and pasted side by side in notepad and could not see anything other than some indentation but then in the actual forum I saw the red.)
It's late in the day and I'm actually supposed to be somewhere else right now so I can't even figure out exactly which post you are responding to.
(Someone said something about the associative checkbox, I have a thread somewhere where I worked with an autodesk rep to try to deal with that and they came to the conclusion that that was no accessible through the API.)
[Sorry, I'll try to be more polite tomorrow, but I don't have time at this particular moment]
Hi Dan,
Here is the Help page on the property, ComponentOccurrences.AllLeafOccurrences.
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-86E425C0-69CD-4004-A6F6-ECB2878B499F
Many thanks!
Hello @Curtis_Waguespack
works great, thank you really much!
One more question, do you know how to filter out parts with BOMStructure = reference (51970)?
best regards
Petr Foltán
Hi @dan_inv09,
If we think of an assembly as a tree, the top level assembly is the trunk, and the sub assemblies are the branches, and each part ( whether in the top level assembly or a sub assembly ) is a leaf.
see this link for a more detailed explanation:
https://modthemachine.typepad.com/my_weblog/2009/03/accessing-assembly-components.html
Also, I wasn't replying to anyone in the thread, but rather I was posting to this thread to assist petr.foltan who had inquired elsewhere about the iLogic example posted here in the past.
As for the Associative Checkbox, I think what you stated is correct. From memory, we can set the associative checkbox for representations for a drawing view, but not at the assembly level. I was thinking it was exposed in the API, but just doesn't work properly??? but it's been a while since I've looked at that so, I could be mistaken.
I hope this helps.
Curtis
Hi @petr.foltan
It would be something along these lines. I'm short on time at the moment, but post back if this isn't enough to get you what you're needing.
If oCompOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure then....
I hope this helps.
Curtis
Thanks for reply @Curtis_Waguespack
I tried it, but without success.
I do not know where to put it right, it did nothing or I get "Object reference not set to an instance of an object"
Petr
Hi @petr.foltan
See this version , note red text.
I hope this helps.
Curtis
'create a design view representation for each unique part in the assembly 'define current document Dim openDoc As Document openDoc = ThisDoc.Document 'set a reference to the assembly component definintion. 'this assumes an assembly document is open. Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition 'look at all of the components in the assembly Dim oCompDef As Inventor.ComponentDefinition = openDoc.ComponentDefinition 'define the first level components collection Dim oCompOcc As Inventor.ComponentOccurrence 'define view rep Dim oViewRep As DesignViewRepresentation 'define an arraylist to hold the list of view rep names Dim NameList As New ArrayList() 'Look at the view reps in the assembly For Each oViewRep In oAsmCompDef.RepresentationsManager.DesignViewRepresentations 'set the list of names to the array list NameList.Add(oViewRep.Name) Next 'check for a Default view rep and create it if not found If Not NameList.Contains("Default") Then 'create Default view rep oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add("Default") oViewRep.ShowAll oViewRep.Activate End If 'zoom all ThisApplication.CommandManager.ControlDefinitions.Item("AppIsometricViewCmd").Execute 'look at all of the unique parts in the assembly For Each docFile In openDoc.AllReferencedDocuments If docFile.DocumentType = DocumentTypeEnum.kPartDocumentObject Then docFName = IO.Path.GetFileNameWithoutExtension(docFile.FullFileName) 'check to see if the arraylist contains the desired view rep If Not NameList.Contains(docFName) Then 'create new View Rep oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add(docFName) ElseIf NameList.Contains(docFName) Then 'reference existing View Rep oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item(docFName) End If oViewRep.Activate oViewRep.Locked = False 'look at all of the occurences For Each oCompOcc In oCompDef.Occurrences.AllLeafOccurrences If oCompOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then Continue For 'locate the colon position in the occurence name oCompOccPos = InStrRev(oCompOcc.Name, ":") 'set occurence name to everything left of the colon oOccName = Left(oCompOcc.Name, oCompOccPos - 1) 'set visible if name matches first occurence If oCompOcc.Name = ShortName & ":1" Then oCompOcc.Visible = True ThisApplication.ActiveView.Update() Else oCompOcc.Visible = False ThisApplication.ActiveView.Update() End If Next End If 'lock view rep oViewRep.Locked = True Next 'set Default View Rep active oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item("Default").activate
It works but not as I want.
I do not want even to create a view representation for this parts with reference BOM structure reference.
Petr
Hello @Curtis_Waguespack,
I have a problem with "oCompDef.Occurrences.AllLeafOccurrences". It tooks parts from all sub assemblies, but when main assembly contains any Frame made by frame generator, it allways ends with this error:
Error in rule: CreateViewRepresentations, in document: assembly.iam
Argument Length must be greater than or equal to zero.
How to solve it?
Yeah I had an error in line 67, and I think it's because I had manually renamed the component in the Assembly Model tree; so I added back in the ":1".
So now it creates view reps for all (albeit in backwards alphabetical order), but the each view is empty (all hidden parts)--guess I gotta manually unhide for now.
