Inventor General
Active Member
Message 1 of 7 (408 Views)
Coding in Inventor (iLogic) - Measure an angle
408 Views, 6 Replies
12-13-2012 11:11 AM
How do I measue angles between faces in a rule? I want to create a simple if statment depending on the angle between a rotating object and a grounded object. If a certain face of the rotating object is 180 degrees relative a face on the fixated object the rotating object is supposed to rotate around its own axis.
I've seen the Measure.Angle-function but I can't get it to work.
Thanks!
*Pro
jletcher
Message 2 of 7 (404 Views)
Re: Coding in Inventor (iLogic) - Measure an angle
12-13-2012 11:31 AM in reply to: eric.vinjegaard
Does it have to be a dimension? are you in an assembly?
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
Active Member
Message 3 of 7 (400 Views)
12-13-2012 11:40 AM in reply to: jletcher
Yes, it´s in an assembly.
Well i I just want the rule to measue the angle between the two faces (two different parts) each time the rule iterates to determine the state of the rotating object. As I mentioned before, the rotating objects' angle relative the ground is supposed to be determined depending on the angle between two faces.
*Pro
jletcher
Message 4 of 7 (398 Views)
12-13-2012 11:43 AM in reply to: eric.vinjegaard
How are you controlling the angle?
James Letcher
Active Member
Message 5 of 7 (394 Views)
12-13-2012 11:53 AM in reply to: jletcher
It is constrained on another object which is rotating and the rotating movement is controlled with an angle parameter.
I simply want a rule to measure an angle between two faces on its own to launch different actions depending on that angle.
*Pro
jletcher
Message 6 of 7 (391 Views)
12-13-2012 11:54 AM in reply to: eric.vinjegaard
Just have the rule read the parameter not a dimension..
James Letcher
Active Member
Message 7 of 7 (385 Views)
12-13-2012 12:04 PM in reply to: jletcher
That´s what I've been doing but I realized that it's not a good way to go. I'm driving the constraint (parameter) now to make the movements the way I want them to be, but later on when I'm going to do simulations the parameter is not going to be the reason the object is rotating. But if i manage to measure the angle between the objects within the code I will be able to determine its position. Do you know if it's possible to do that?
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
