Inventor Forum
Close file and delete local copy no longer works
1 REPLY 1
Neil_Cross
315 Views, 1 Reply
On multiple machines we have Inventor 2013 SP1.1 Update 2, fully hotfixed.  Recently, it's pretty obvious when checking into Vault and choosing 'Close files and delete working copies' this isn't performing as expected.  It defintely used to work perfectly, but I'm talking about the last few months something has changed.
Following a check in, it no longer closes the file.  However, it does delete the local copy.  Leaving a bizarre situation where you have a model open in session but the local copy has gone.  When then closing the session, (another issue entirely) it asks you to save it again even though there's nothing to save... if you say yes, it then tells you there's no local copy!
It's not a massive issue by any stretch, just slightly irritating, and it's happening on multiple different PCs.  Anyone come across this and figured out what it is?
Cheers.
1 REPLY 1
r.smith1
in reply to: Neil_Cross
Hi Neil,
When you experience the issue, how was the file opened?
Was it
  • Opened directly from Vault explorer
  • Opened from the local workspace
  • Open From Vault command in Inventor
Ron Smith
New Product Introduction Manager
Autodesk, Inc.
