Inventor General
New Member
upod123
Message 1 of 4 (109 Views)
Circular Welds - Computing Mesh
109 Views, 3 Replies
12-19-2013 09:57 AM
I am trying to use the FEA program to find the stress in a vessel head. The head has two nozzles and each of the nozzles has a repad. I am able to add welds to the repads to connect them to the vessel head, but whenever I try to run the FEA analysis for the vessel, I get a "Mesh Error: Body Failure" for each of the welds at the vessel head. Any ideas on how to correct this? I have attached the file with one of the welds in place. ANy help is greatly appreciated.
*Expert Elite*
JDMather
Message 2 of 4 (104 Views)
Re: Circular Welds - Computing Mesh
12-19-2013 10:21 AM in reply to: upod123
An assembly file (*.iam) is only a list of hyperlinks to the part files (*.ipt) and a record of assembly constraints (and a bit more).
You must include the part files.
I recommend that you not include the welds in the analysis (should not be needed) and you need to indicate the Inventor version (if 2014 there is a Registry edit you need to make).
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
New Member
upod123
Message 3 of 4 (98 Views)
12-19-2013 10:33 AM in reply to: JDMather
I am very new to using Inventor. All parts for this model were made in AutoCad and then exported to INventor for analysis. Where would the individual part files be located if this is the case?
*Expert Elite*
blair
Message 4 of 4 (68 Views)
12-19-2013 09:21 PM in reply to: upod123
Navigate to where the Head E FEA.Iam file is located with Windows Explorer, then RMB on the file and select the Pack-And-Go. It will find all related files to the assembly and place them in a ZIP file that you can upload.
IV2015 up1 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
