Inventor General
Active Member
g.fleming
Message 1 of 3 (425 Views)
Circular Pattern Feature Revolution
425 Views, 2 Replies
03-04-2004 08:27 AM
I'm sure that other people in other revisions of Inventor wished to have the same flexibility in choosing to rotate or not rotate features in a circular pattern, as in AutoCAD's Polar Array command.
I hope this makes it to a feature wish list.
*Tom Sturtevant \(Autodesk\)
Message 2 of 3 (425 Views)
Re: Circular Pattern Feature Revolution
03-04-2004 08:47 AM in reply to: g.fleming
You can accomplish this with the Rectangular Pattern command by selecting a circular path. If you expand the rectangular pattern dialog (with the ">>" button) there is an "Orientation" setting. If this is "Identical" the features will not be rotated, if it is "Direction1" they will rotate. To get this to work properly you need to select a Start point (also in the expanded part of the dialog) on the circular path at the "center" of the features you are patterning. The start point can be a sketch point, or a work point. Hope that helps. Tom Sturtevant Inventor Part Modeling "g.fleming" wrote in message news:27669337.1078417692647.JavaMail.jive@jiveforum2.autodesk.com... > I'm sure that other people in other revisions of Inventor wished to have the same flexibility in choosing to rotate or not rotate features in a circular pattern, as in AutoCAD's Polar Array command. > > I hope this makes it to a feature wish list.
*Quinn Zander
Message 3 of 3 (425 Views)
03-04-2004 08:51 AM in reply to: g.fleming
You CAN do this but only in the Rectangular Pattern command when you array down a path (sketch line, edge) The trick with circles is to specify a start (sketch) point on the sketch. QBZ "g.fleming" wrote in message news:27669337.1078417692647.JavaMail.jive@jiveforum2.autodesk.com... > I'm sure that other people in other revisions of Inventor wished to have the same flexibility in choosing to rotate or not rotate features in a circular pattern, as in AutoCAD's Polar Array command. > > I hope this makes it to a feature wish list.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
