In Inventor 2012, you could choose Balloon, select a part, click at some location and the Balloon was placed and finished. Now in Inventor 2013 you have to right-click and choose Continue. The same applies, when you want to place a Leader Text (and maybe elsewhere as well).
Why do we suddenly have to make two additional clicks compared to Inventor 2012. It doesn't help, that you can press Enter instead of the additional mouse clicks.
And why is the Open Drawing moved to second level. The Marking Menu is of no help, especially not in the tree browser.
Why do you Inventor designers make such changes that make Inventor more annoying to operate compared to the previous version. It should be the other way around....like the brilliant inclusion of Open Drawing.
regards,
Jorn
Solved by SBix26. Go to Solution.
Hi Jl
Comparing Inventor 2012 , Inventor 2013 has same behavior on placing balloon or leader text, right-click and choose continue, or press Enter to confirm current positioning.
I do agree with you that it's inconvenient to find the open drawing command now, since you mentioned Marking menu, here is a workaround that you can customize marking menu, at least it can help you put things right once and for all.
Placing balloons has always required finishing, since you could continue clicking to place additional jogs in the leader. But did you know that double clicking to place the balloon finishes the command? I think I learned this accidentally when I got a little too "twitchy" with the mouse button one day.
To Jingyi Liu
The Marking menu is not perfect since you need to press Ctrl while right-clicking. Unfortunately I cannot now recreate how I did in Inventor 2012 (must try at home where 2013 is yet not there to maybe interfere). But the double-click solution by sbixler must be the solution for me.
Thanx for your answer.
regards,
Jorn
