Inventor General
Active Member
Message 1 of 3 (830 Views)
Changing multiple face colors
830 Views, 2 Replies
10-01-2012 06:22 AM
Hi folks,
I'm working with Autodesk Inventor 2009.
I have several parts colored in gray, black and red.
  • The grey color is the basic part color/material.
  • The black color is feature color styles.
  • The red color is face color styles.
I need to change all the face color styles (red) to the original part color/material (gray/default). I can do this by right-clicking on a surface > properties > face properties.
My problem is that I have a lot of surfaces (mostly due to fillets). I can choose multiple ones wth ctrl + click, but even that would take forever.
Is there an easier way to change all the face colors at once?
Best regards
A. Heiselberg
Employee
Message 2 of 3 (797 Views)
Re: Changing multiple face colors
10-01-2012 03:42 PM in reply to: aheiselberg
Hi! If you were on R2010, it would be fairly simple to do. Just right-click on the solid body node in the browser -> Properties -> Strip color overrides. However, you are on R2009.
On top of my head, there are three ways to do this without actually selecting the faces manually.
Option1: You can simply rename the document color style from Red to something else. Then change the color to be like gray.
Option2: You can find a planar face or any face on the part. Create a zero-offset surface on the face. Then use Delete Face command to delete the selected face. Next, create another zero-offset surface using Qulit option. Use Delete Face command to remove the original quilt. Lastly, use Sculpt or Stitch to turn them into a solid again. This workflow is a bit confusing. Please see attached part for more information.
Option3: If you are familiar with VBA, you might be able to create a small program marching over the faces and resetting the face color to something else.
Thanks!
Principal SQA Engineer, Inventor
Mechanical Design
Active Member
Message 3 of 3 (777 Views)
10-02-2012 12:14 AM in reply to: johnsonshiue
Thank you for your help. I managed to get it done in a way similar to your 1st solution.
Thanks again!
BR
A. Heiselberg
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
