I noticed some errors in certain table entries in an iFeature of mine after I had already started creating parts using it. I've updated the table and when I add new instances of the feature to my part they work fine, but the existing instances of it stay the same size. Is there any way to force the existing instances to update?
The iFeature in question is a sketch and I'm using Inventor 2012, if either of those is relevant.
Thanks!
Did you try using the rebuild command?
Also if you are using these iparts in assemblies you might want to regenerate the iparts.
Yes, rebuild doesn't seem to help.
Is any part with an iFeature automatically an iPart? My parts just have slots in them based on a sketch which is an iFeature.
