Inventor General
Active Contributor
rjezuit
Message 1 of 8 (4,666 Views)
Changing Drawing Sheet Size
4666 Views, 7 Replies
06-14-2012 02:11 PM
I have 4 different sized drawing templates made, one each for A,B,C and D size. There are times when I start a drawing on a C size border/sheet and it gets too cluttered as I add views or annotations. Is there any way to insert/change the sheet size to the D sized template without starting over?
JDMather
Message 2 of 8 (4,657 Views)
Re: Changing Drawing Sheet Size
06-14-2012 03:02 PM in reply to: rjezuit
You should have all your sheet sizes, borders and titleblocks set up in the Drawing Resources of one template.
You can copy these from one file to another and simply right click to change.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Contributor
rjezuit
Message 3 of 8 (4,622 Views)
06-15-2012 01:56 PM in reply to: JDMather
Then would I have to setup each individual drawing every time depending on size? Pick sheet size , border and title block every time I create a drawing? It seems like I would be doing extra work on every single drawing produced versus changing the occasional drawing where I would run into this.
JDMather
Message 4 of 8 (4,617 Views)
06-15-2012 01:59 PM in reply to: rjezuit
If most of your drawings are the same size then set this as default.
Alternatively you could simply have all information in one template, make appropriate active and then Save As template for that size.  Then simply start with what you think will be appropriate template, and if you end up needing to change - all of the information is in the drawing resources.
Set it once, and forget it.
Active Contributor
rjezuit
Message 5 of 8 (4,591 Views)
06-18-2012 05:15 AM in reply to: JDMather
I have not tracked which size I use the most, but I use all 4 sizes regularly. I thought it should be relaitvely easy like it is with AutoCAD, but I guess not. It would be nice if you could just cut and paste the existing borders/titlebloacks/sheet size into an existing drawing.
Active Contributor
helmartins
Message 6 of 8 (4,581 Views)
06-18-2012 05:50 AM in reply to: rjezuit
Hi
the I logic can resolve your question.. Just changing the title blocks and the borders..
 Im having the same problem here(with the sheet sizes), but I'm getting an Ilogic error. I think when this one can be resolved, you can change the size without start over.
I post this issue in the link below. Hope to solve it soon. hehe
http://forums.autodesk.com/t5/Autodesk-Inventor/Ilogic-error-changing-sheet-border-and-title-blocks/...
Helder Martins
*Pro
sbixler
Message 7 of 8 (4,559 Views)
06-18-2012 11:02 AM in reply to: rjezuit
We have five different sheet sizes, but all the resources are in each drawing file: five borders and two title blocks.  That makes it relatively easy to switch: delete border (and possibly title block), change sheet size, add appropriate border (and possibly title block).
We have an iLogic rule that runs on a new file to present the user with a choice of sizes, then set the sheet size and place the right border and TB.  I want to modfy it to also allow changing the size, keeping the prompted value field data that already exists.
New Member
alphil
Message 8 of 8 (367 Views)
06-12-2014 07:43 AM in reply to: rjezuit
I've had the same issue a few times with Inventor 2013. If you go to the model tree on the left side of the screen, right click on "Sheet:1" (or whatever yours says), a menu pops up. Click "Edit Sheet" and in the box that subsequently pops up, there is the option to change the sheet size of your existing drawing without changing anything that you've done already (notes, dimensions, etc.). I've attached 2 photos for your viewing pleasure.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
