Hi All,
I am having a problem changing my tjube sizes. Basically when I create a new route and populate the route, I want to be able to change the size without adding hundreds of sizes to the library. So I right click on the tube and select change size. The when I select a different size and select apply nothing happens? I push update and still nothing happens? When I try to change the tubing size again it shows the size that I change it to but the tube doesn't visually change? I have noticed the same with the hose. What I also noticed is when you change the size on pipes it does change. So can someone please explain to me how it is possible to change the piping sizes by right clicking on it and select change size when this function doesn't seem to work on the tube and hose? I am still very new to the pipe and tjube, but I believe if the option is there it should work?
Kind regards,
iUser
What version of Inventor are you using? Would it be possible to post a small dummy assembly that shows this behavior for folks here to play with?
Meanewhile, I will try to play with this on my test system to see if I can duplicate it... but I am on 2013 so results may not be the same.
UPDATE:
I have been able to duplicate this with 2013, using the only tube style I have active right now, a copper tube. I created a run at 1/2", including a coupling in one spot. Route populated as expected. Change size appears to work as you mentioned, and DOES work on the fitting.... but the tube size does not update.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Was there ever a resolution or explanation to this problem? It would seem that with the complexity of changing rigid piping size that changing tube or hose size would be easy.
Keith
