Inventor Forum
Change Content Center part to a normal ipt
13 REPLIES 13
Message 1 of 14
6926 Views, 13 Replies
I have a part that was made from content center and modified further.  I would like Inventor to no longer recognize this part as a content center part.  It has been renamed and migrated to 2013 format, but still when inserting into an assembly the assembly recognizes it as a content center part in the browser.
Also, the browser title for the part will not update with the filename.
13 REPLIES 13
Message 2 of 14
cbenner
What is the part?  Can you post the file?  There are work features added to a part when it is published to the CC.  It may be as simple as removing these work features.  But what those are depnds on what the part is.
Message 3 of 14
LT.Rusty
Open from content center --> save as.
Should be as simple as that.  I've got a bunch of stuff that I've done that with, and it doesn't show as a CC part anymore.
Changing the browser name though, I think you have to do that manually once the file is open.
Rusty
Message 4 of 14
Cadmanto
See if this link helps you.
http://forums.autodesk.com/t5/Autodesk-Inventor/Fitting-type-removal/m-p/3066678/highlight/true#M405...
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 5 of 14
Carthik_Babu
hi,
kindly read this blog, it will solve the issue.
http://beinginventive.typepad.com/being-inventive/2012/07/place-a-tube-pipe-fitting-in-an-assembly-a...
I got thisbelow macro from the above site(bit modified for Autodesk Inventor 2011). I saved this as external macro and applied the macro to the part file which has been placed from content center as "Custom". The Macro solved the issue.....
Sub Main()
strip_CC()
End Sub
Sub strip_CC()
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
'Check to see if it is not a true content center part . otherwise bail out
If oDoc.ComponentDefinition.IsContentMember = False Then
' Enable all commands and set the subtype to a standard part.
oDoc.DisabledCommandTypes = 0
oDoc.SubType = "{4D29B490-49B2-11D0-93C3-7E0706000000}"
' Optionally clean up other Content Center related properties.
On Error Resume Next
oDoc.PropertySets.Item("Content Library Component Properties").Delete
Dim DTPropSet As PropertySet
DTPropSet = oDoc.PropertySets.Item("Design Tracking Properties")
DTPropSet.Item("Catalog Web Link").Value = ""
oDoc.Save
End If
End Sub
Carthik Babu M.S, Asst Manager - Machine Building,
Gabriel India Ltd,Hosur, TN, INDIA
Email:carthik_ms@yahoo.co.in ,
https://grabcad.com/carthik-1/projects
"May all beings be happy" http://www.dhamma.org/
Message 6 of 14
Carthik_Babu
in reply to: Carthik_Babu
Kindly find the code for converting the selected "custom content center Part file" in an assembly to Normal File. Hope it will be useful for someone who search for the same.
Sub Main()
Dim oOcc As ComponentOccurrence
oOcc = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Pick occurrence")
strip_CC(oOcc)
End Sub
Sub strip_CC(ByVal oOcc1 As ComponentOccurrence)
'Dim oDoc As PartDocument
'oDoc = ThisApplication.ActiveDocument
Dim oOccDef As PartComponentDefinition
oOccDef = oOcc1.Definition
' Just open it in the background
asm = ThisApplication.Documents.Open(oOccDef.Document.FullFileName, False)
If oOccDef.Document.ComponentDefinition.IsContentMember = False Then
oOccDef.Document.DisabledCommandTypes = 0
oOccDef.Document.SubType = "{4D29B490-49B2-11D0-93C3-7E0706000000}"
MsgBox(oOccDef.Document.FullFileName)
oOccDef.Document.PropertySets.Item("Content Library Component Properties").Delete
DTPropSet = oOccDef.Document.PropertySets.Item("Design Tracking Properties")
oOccDef.Document.Save
End If
End Sub
Message 7 of 14
tegstette
HiSmiley Happy
This rule Works great from an Assembly by picking the part I want to make normal.
But is it possible to rewrite the rule so it can be run directly on the ipt?
I would be very glad if you or someone else could help me out very soonSmiley Happy
Best regards
TG
Autodesk Inventor/Vault Professional 2021
Message 8 of 14
tegstette
in reply to: tegstette
I figured it outSmiley Happy
I used the code above and modified a little to my need.
Best regards
TG
Message 9 of 14
mcgyvr
@tegstette
Do you mind posting your updated code that worked for you so others can benefit from it?
Message 10 of 14
Curtis_Waguespack
in reply to: mcgyvr
Hi mcgyvr,
I use a version of this with iLogic.
I hope this helps.
Curtis
Run in the part file:
Try
	ThisApplication.ActiveDocument.PropertySets.Item("Content Library Component Properties").Delete
	MessageBox.Show("KA-POW!" & vbLf & "Content Center Properties smashed!", "iLogic")
Catch
	MessageBox.Show("huh?" & vbLf & _
	"Something didn't work..." &vbLf & _
	"...file is read only maybe?" &vbLf & _
	"...file has no Content Center Properties, maybe?" &vbLf & _
	"...other?", "iLogic")
End Try
Message 11 of 14
Very nice!
Message 12 of 14
@Curtis_Waguespack, Do you know if it is possible to restore the symbol to the default for an IPT file?
Message 13 of 14
Hi lackas5C4Z4,
Give this a try. I didn't have time to test it much, post back if you run into problems.
Note you might to save or do a rebuild all on the assembly to see the icon for the component change, if the part was already placed in an assembly and that assembly is open.
I hope this helps.
Curtis
oError = 0
Try
	oErrorMessage1 = ""
Catch
	oError = oError + 1
	oErrorMessage1 = "PropertySet not found: Content Library Component Properties"
End Try
Try
	ThisApplication.ActiveDocument.PropertySets.Item("ContentCenter").Delete
	oErrorMessage2 = ""
Catch
	oError = oError + 1
	oErrorMessage2 = "PropertySet not found: ContentCenter"
End Try
If oError = 2 Then
ElseIf oError = 1 Then
	MessageBox.Show(oErrorMessage1 & vbLf & _
	oErrorMessage2, "iLogic")
Else
End If
Message 14 of 14
This worked beautifully. Didn't even have to rebuild the assembly. Thank you very much!
Note: it did throw an error on the parts where I used the previous script but still got the job done.
