Inventor General
Message 1 of 3 (379 Views)
Change Base View
379 Views, 2 Replies
01-24-2013 07:47 AM
I was wondering if there was a way to change the model my base views were linked to.
If I wanted to link the base view to a different model, would this be possible.
When I double click on the base view it shows the file path for the model that is currently chosen; however, it is all grey and I am unable to edit it or choose another file path.
Does anyone know how to change this?
Is this even possible?
Is it because I have annotated the drawing view that I am unable to change the model path?
Please let me know (if you do).
Vijai Christopher Sookrah
Project Engineer, EIT
AAE Ltd.
Valued Mentor
mpatchus
Message 2 of 3 (375 Views)
Re: Change Base View
01-24-2013 07:54 AM in reply to: vsookrah
Sure simply go to the MANAGE tab and select REPLACE MODEL REFERENCE.base view.JPG
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
Curtis_Waguespack
Message 3 of 3 (370 Views)
01-24-2013 07:58 AM in reply to: vsookrah
Hi  vsookrah,
Keep in mind that the tool that mpatchus refers to was introduced in Inventor 2011 (or Inventor 2010 if you loaded the subscription tools). I thought I'd mention that in case you're using an early version or in case someone else who is using an older version finds this post and is wondering why they don't have that tool.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
