I just upgraded from 2010 to 2012 and am having trouble making centerlines on holes using the centerline bisector. I am looking at the length of the hole and I want to add a center line along the length, I used to use the bisector option to do this, now it won't even let me pick the lines which represent the hole?? Any idea's why? I also can't make certain lines in a drawing non-visible like i used to .
Tyson
Solved by tysonwitte. Go to Solution.
Attach a file here that exhibits this behavior.
