Inventor General
*Fred Payne
Message 1 of 9 (371 Views)
Center point visibility : dwg import
371 Views, 8 Replies
09-17-2009 01:12 PM
I imported some dwg blocks into Inventor with the
idea that I use them in conjunction with other parts in an
assembly.
Having done so, I can't hide the center points. Any
suggestions? Am I missing something obvious? See attached view.
I need a cure for imeasles.
Lawrence
IV series 2010
Employee
Message 2 of 9 (371 Views)
Re: Center point visibility : dwg import
09-21-2009 10:15 AM in reply to: *Fred Payne
There currently is no way to supress the visibility of the sketch point geometry but we are looking into the issue. Thank you!
Ralf Walter (Autodesk)
*Fred Payne
Message 3 of 9 (371 Views)
09-21-2009 10:48 AM in reply to: *Fred Payne
OK. Thanks. I got a lot of work to do then recreating.
regards .............. Spotty Muldoon Esq.
"ralfwalter" wrote in message news:6257767@discussion.autodesk.com...
Active Member
Message 4 of 9 (270 Views)
10-24-2012 01:02 AM in reply to: *Fred Payne
I got the same issue here, and i wonder if there is already a solution for this problem. (because the thread is from 2009). I'm using inventor 2013.
Valued Contributor
Message 5 of 9 (221 Views)
02-04-2013 04:51 AM in reply to: ralfwalter
i also get into the same issue
is there something done meanwhile?
Message 6 of 9 (212 Views)
02-04-2013 07:40 AM in reply to: michael.marx
You could set Tools>Application Options>General tab to a real small value on Annotation Scale to make them less visible, but this will also make sketch dimension annotations very small.
http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Valued Contributor
Message 7 of 9 (209 Views)
02-04-2013 07:44 AM in reply to: JDMather
Thank you for the input but that´s not what i´m searching for
Message 8 of 9 (204 Views)
02-04-2013 08:04 AM in reply to: michael.marx
No.
New Member
Message 9 of 9 (152 Views)
04-03-2013 04:38 PM in reply to: *Fred Payne
I just found that by going to properties for the sketch into which you've imported the ACAD drawing, you can change lineweight and all the points become far less prominent.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
