Inventor General
Member
1207463
Message 1 of 5 (334 Views)
Cant extrude in assemble drawing
334 Views, 4 Replies
04-04-2013 11:51 AM
Can’t extrude in assemble drawing in inventor when I draw a sketch and finish sketch
And try to extrude the sketch it extrudes but only in cut mode  it is the only button that is working the rest are all faded out
Curtis_Waguespack
Message 2 of 5 (332 Views)
Re: Cant extrude in assemble drawing
04-04-2013 11:53 AM in reply to: 1207463
Hi 1207463,
This is called an Assembly Feature. And that is just the way it works, you're only able to mill/remove material from the assembly level, if you need to add material just edit the part and create the sketch in that part.
The reason behind this goes something like this: Imagine we have a part that we make and stock in inventory, but in some assemblies we add a hole and a kerf notch to the part. We don't want these modifications in every place the part is used, so placing the feature at the assembly level let's us have this flexibility.
Also just as a tip, you might want to use the words "assembly file" rather than "assembly drawing". Typically in Inventor assembly drawing refers to a drawing file (IDW or DWG) that details an assembly. Same goes for "part file" vs. "part drawing".Just a minor point, but it helps make your questions easier to understand.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Cadmanto
Message 3 of 5 (320 Views)
04-04-2013 12:04 PM in reply to: 1207463
Your best bet would be to RC on the part in the assembly browser and edit it within the assembly to add the protruded feature you need.
A specially if you are trying to create or do top down engineering.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
Member
1207463
Message 4 of 5 (297 Views)
Re: Can't extrude in assemble drawing
04-04-2013 01:00 PM in reply to: Curtis_Waguespack
Thanks managed to work it out was doing it **** from elbow create sketch then create part on sketch
Cadmanto
Message 5 of 5 (289 Views)
04-04-2013 01:15 PM in reply to: 1207463
Marking this thread as solved and what exactly helped you would help others in the future with similar issues.
Best Regards,
Scott McFadden
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
