Inventor General
New Member
Message 1 of 4 (177 Views)
Cant change my dimensions
177 Views, 3 Replies
10-28-2012 05:57 AM
I use autodesk inventor proffesional 11 and when I try to change the dimensions it dosent work.
Any help please
*Expert Elite*
Message 2 of 4 (170 Views)
Re: Cant change my dimensions
10-28-2012 08:30 AM in reply to: simon.mcginlay
Can you attach the ipt file here?
Is this Inventor 11 or really 2011?
Are you in an active sketch?
What happens if you double click on the dimension?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
New Member
Message 3 of 4 (125 Views)
10-29-2012 11:09 AM in reply to: JDMather
I have Inventor Professional 11, I can type in a dimension but when I click the tick or press enter it wont change.
*Pro
sbixler
Message 4 of 4 (113 Views)
10-29-2012 11:47 AM in reply to: simon.mcginlay
Read over your postings so far-- do you think that you have given us enough information to understand the problem?  There are several different environments within Inventor where dimensions may be entered, so you will need to give much more detail: pictures and/or files, and describe step by step what you are doing.  None of us here can see your monitor or read your mind...
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
