Inventor Forum
Cant change my dimensions
3 REPLIES 3
simon.mcginlay
399 Views, 3 Replies
I use autodesk inventor proffesional 11 and when I try to change the dimensions it dosent work.
Any help please
3 REPLIES 3
JDMather
in reply to: simon.mcginlay
Can you attach the ipt file here?
Is this Inventor 11 or really 2011?
Are you in an active sketch?
What happens if you double click on the dimension?
simon.mcginlay
in reply to: JDMather
I have Inventor Professional 11, I can type in a dimension but when I click the tick or press enter it wont change.
SBix26
Read over your postings so far-- do you think that you have given us enough information to understand the problem?  There are several different environments within Inventor where dimensions may be entered, so you will need to give much more detail: pictures and/or files, and describe step by step what you are doing.  None of us here can see your monitor or read your mind...
