I'm trying to apply an M13 x 1 Thread on a 13mm O.D. cylinder but the strangest thing is that there is no M13 thread available in the drop down (seems to skip from 12 to 14). It defaults to an M14. Does anyone know why this is?
i never used a m13 thread before, i think its not a regular mate...
maybe u can find it on trace parts online or somthing?
good luck
You can add a custom thread type. Its easy!
The Thread.xls file, which is located in the Design Data folder, provides data for hole and thread commands.
The Thread.xls spreadsheet contains various worksheets in one of two formats: Parallel Thread Type or Taper Thread Type. The worksheets contain some common industry standard thread types and standard tapped hole sizes. You can edit the worksheets to:
Font: Inventor Help:
Always back-up your copy of Threads.xls before editing.
The solution is simple.
When the "Thread" dialog pops up, select the cylinder surface then apply - the job is done.
See the attachment.
HTH
Edit: Because the "thread" is an image not a solid - nobody can measure the M13x1 thread on the model.
