Inventor General
Active Contributor
Message 1 of 7 (1,222 Views)
Accepted Solution
Cannot snap to sketch line midpoint (no green dot) 2013
1222 Views, 6 Replies
11-26-2012 08:28 PM
Hi All
Hopefully this is an easy one...
When I use a tool such as 'move'/'select base point' in the sketch environment, I used to be able to select line midpoints.
Is this no longer possible?
My constraint options seem to be fine...
Recently upgraded to 2013
Grant
Employee
Xun.Zhang
Message 2 of 7 (1,212 Views)
Re: Cannot snap to sketch line midpoint (no green dot) 2013
11-27-2012 12:54 AM in reply to: ggoodey
Hello, ggoodey
Thanks for your question, unfortunately, the Mid Point not supported for base point selection so far, please create a contribution line which could snap to the Mid point first to help identify the real point for the base point when you try to move the sketch with Mid point.
I will submit a wish to out internal system for enhancement in the future, thanks a again.
Xun Zhang
Software QA Engineer
Inventor Quality Assurance Team
Autodesk, Inc.
Active Contributor
Message 3 of 7 (1,190 Views)
11-27-2012 12:04 PM in reply to: Xun.Zhang
Thanks Xun
I was so sure I could do this pre-2013
Never mind...
Employee
Xun.Zhang
Message 4 of 7 (1,172 Views)
11-27-2012 05:33 PM in reply to: ggoodey
Hello, ggoodey
Checked in several release pre-2013, such as 2011 and 2012, your requirement not supported, a wish tracked in our system, we hope it will be fix in a short time, and I will let you know once it got fixed.
Xun Zhang
Autodesk, Inc.
Active Contributor
Message 5 of 7 (1,168 Views)
11-27-2012 05:43 PM in reply to: Xun.Zhang
No worries!
Thanks again
Active Member
Message 6 of 7 (1,155 Views)
11-27-2012 11:41 PM in reply to: ggoodey
Hello !
I tried to move a Sketch block ( Insert point selection)
but could not.
It will be usefull to select Midpoint  also Sketch block.
Sorry,Long line !
Inventor2012,2013
Windows7 64bit
Japan
Employee
Xun.Zhang
Message 7 of 7 (1,150 Views)
11-27-2012 11:49 PM in reply to: yomogidami
Hello, yomogidami
Yes, we noticed that it will be better if mid point supported when sketch move, thanks for your follow up question, I'll reply you once it got fixed.
Many thanks for your questions again.
Xun Zhang
Autodesk, Inc.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
