Inventor General
Distinguished Contributor
Karol-Or
Message 1 of 12 (458 Views)
Cannot select by window dragging
458 Views, 11 Replies
06-23-2012 09:54 AM
I made a complex sketch, and want to extrude.
When i want to select the whole sketch, i position the mouse on the upper left of the screen and drag down and right, but no window is created.
And i cannot add segments to the selection, even with pressing SHIFT, because immediately after the first is selected, it is extruded.
Third question: you see on the picture i attached that some segments (in red) are connected. how can i connect all the sketch together, so when i will select it everything is selected.
Thanks-Karol
*Expert Elite*
JDMather
Message 2 of 12 (455 Views)
Re: Cannot select by window dragging
06-23-2012 11:25 AM in reply to: Karol-Or
I recommend you pattern a feature rather than sketch entities for that part..
If you want to fix that sketch you will need to run the Sketch Doctor.
It will tell you that you are missing some coincident constraints.
If you can't figure it out - attach the file here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Karol-Or
Message 3 of 12 (421 Views)
06-24-2012 11:14 AM in reply to: JDMather
You are correct, there is at least one open loop.
What does this sign of constraint mean? i didn't find it in the help.
Why are the two arcs marked as red?
Karol
*Expert Elite*
JDMather
Message 4 of 12 (414 Views)
06-24-2012 02:31 PM in reply to: Karol-Or
I cannot show you the problem without the file.
I could take 5 minutes to reproduce this simple problem, but since you have already created the geometry.....
I think you are referring to the patterned sketch geometry constraint.
Karol-Or
Message 5 of 12 (385 Views)
06-25-2012 10:50 AM in reply to: JDMather
I attach the file.
You are right, i made a pattern. i didn't find that kind of constraint in the help, can you send me a link?
And why only one adjacent repetition of the line appears marked in red? the pattern includes about 16.
*Expert Elite*
mcgyvr
Message 6 of 12 (380 Views)
06-25-2012 11:02 AM in reply to: Karol-Or
Just do it like this...
We all tend to avoid sketch patterns in favor of feature patterns.
See attached..
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Karol-Or
Message 7 of 12 (374 Views)
06-25-2012 11:39 AM in reply to: mcgyvr
Please save it in 2008 version
*Expert Elite*
JDMather
Message 8 of 12 (352 Views)
06-26-2012 04:48 AM in reply to: Karol-Or
Edit Sketch.
Go to wireframe view.
Doesn't look symmetrical to me?
Only one dimension - shouldn't there be several?
Right click and select Show all Constraints.  Inventor has to solve those.
Right click on sketch in browser and select Sketch Doctor and Diagnose.
Start over.
Make 1/20 sketch.
Create feature.
Pattern feature.
Attach your new attempt here if you can't figure it out.
See this thread http://forums.autodesk.com/t5/Autodesk-Inventor/Cannot-select-by-window-dragging/td-p/3513036
See Tip #27 pg 11
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
*Expert Elite*
JDMather
Message 9 of 12 (324 Views)
06-27-2012 06:44 PM in reply to: JDMather
Did you figure out this problem yet?
Karol-Or
Message 10 of 12 (295 Views)
06-28-2012 11:12 AM in reply to: JDMather
no, i asked mcgyvr to save the file as 2008, and he didn't, yet
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
