When I start a new document or open a file in Inventor, I get a pop up saying: "Cannot read texture image C:\Useers\public\Documents\Autodesk\Inventor 2011\Textures\Chrome.dds"
I moved the whole Autodesk file and changed all paths under settings>files in Inventor. The new path to Chrome.dds is C:\Users\Kaj\Documents\Autodesk\Inventor 2011\Textures\Chrome.dds
Inventor works fine but the pop up is really annoying. What can I do about it?
Thanks in advance.
Solved by Mark_Wigan. Go to Solution.
where did you say you specified the texture file path?
the setting i know of from memory is found under application options, colours... filename. if you changed it there is it still doing it?
Can you show me how to do that? I'm constantly experiencing an issue where I keep recieving a message stating "Cannot read texture image"
Solution:
Go to windows security options and TURN OFF Controlled Folder Access.
steps
-windows security
- virus & threat protection
-under Ransomware protection click "manage ransomware protection"
-Either Turn Off or remove the folder from the list of protected folders.
Hi Mark, I am getting this error as well but do not quite understand your response. Could you state it in simpler, more thorough language? Here are my issues:
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Hi! Please go to Tools -> App Options -> Colors.
Many thanks!
this solved my issue!
Thank you
What i did was allow an app to have access to protected folders instead. (found inventor.exe in folder and selected it)
