Inventor Forum
Cannot "un-slice" the model in my ipt file
9 REPLIES 9
Message 1 of 10
SACdwg01
802 Views, 9 Replies
Hi all
Hope you can help with this. I am a relative new Inventor user and have a problem with a part file that seems to be permanently sliced, or sectioned.
I am not even sure how this happened. Even when I add a new solid to the drawing this part is sectioned.
How do I turn this off?
Please help.
Maia
9 REPLIES 9
Message 2 of 10
johnsonshiue
in reply to: SACdwg01
Hi! Go to View menu -> click on Section View dropdown -> End Section View.
Thanks!
Software Test Engineer
Message 3 of 10
rhasell
Hi
"A picture is worth a thousand words"
Click on View Tab, change view to "End Section View"
Reg
2024.2
Please Accept as a solution / Kudos
Message 4 of 10
SACdwg01
in reply to: rhasell
Thanks guys
Unfotunately it is not as easy as that. For a singl part it doesn't have a section view pull down. Also the Slice Graphic icon is not active. Please see attached.
Any other possibilities/ suggestions?
Regards
Message 5 of 10
rhasell
Been a while since I worked on 2011.
I am not sure where to go.
Give this a try.
Just below the "Two Lights" button is a small expansion arrow. Click on that and see if there are additional features available.
Reg
2024.2
Message 6 of 10
Rory_M
It sounds like Section Analysis is on.
Go to the inspect tab > Section as shown in the attached image.
Alternatively, look at the top of the model browser for a cross section as shown. Again, shown in the attached image.
Rory
Message 7 of 10
SACdwg01
in reply to: Rory_M
Rhassel
No there are no extra features available when I click the expansion arrow. the only thing there is the "Transperancy" feature which is not active.
Rory, the Section analysis is not on. There is nothing in the browser.
More than anything this is a pain because I can edit it in the assembly and the  part is "whole" again. The idw file is fine, it is just the ipt file.
Thanks for your suggestions, I'm sure there is someone out there who can figure it out.
Message 8 of 10
johnsonshiue
Hi! I don't understand this behavior. Could you attach the file here or send it to me directly (johnson.shiue@autodesk.com)?
Thanks!
Message 9 of 10
SACdwg01
in reply to: johnsonshiue
Hi Johnson
I have sent this file to you.
Cheers
Message 10 of 10
johnsonshiue
Hi! I took a look at the part. It seems that the slice graphics is enabled when Sketch22 was edited. Simply edit the sketch and press F7 (or right-click and select Slice Graphics option).
Thanks!
