Inventor Forum
Cannot place second restaint
3 REPLIES 3
95 Views, 3 Replies
I have placed a file in the customer file area (with the same name) of a
tutorial that I'm doing and no matter what I do I can't place the second
restraint. The tutorial says to pick one of the small holes on the
retainer then one of the small holes on the body, this works fine but
then I can't get the second one to work. It has me pick insert then the
back face of the retainer and the front face of the body. I get an error
saying that I need to delete a constaint or suppress it. I have tried
several things to get this to work but can't.
Please take a look at the file if you have time and tell me what I'm
doing wrong.
Thanks for any help, Rich
3 REPLIES 3
On the flange plate the holes are not on the same bolt circle. One of them
is called out at 75mm but the other two are at 75.0002896 mm from the
center. A good way to nail these down is to create a construction line
circle and then place the holes on this circle. Or make one hole and then
do a polar array of the hole. Since they are not on the same BC they will
not align with the pipe part.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
http://www.sdotson.com/faq.html
"Rich" wrote in message
news:24B711AD5A5DF46514619856C84BBA44@in.WebX.maYIadrTaRb...
> doing wrong.
Thanks, I remade the part and everything went as expected. Why was the
error message telling me that I had to remove a constraint when that
wasn't the error? I'm new to this and I was hoping that when things
don't assemble correctly that it would be a little more helpful as to
why the assembly failed, like turn the offending parts red?
Thanks for the help, Rich
"Sean Dotson" wrote in message
news:0DE1238D40DD3A9DBF35E04C4D7ABA84@in.WebX.maYIadrTaRb...
them
line
then
will
> Sean Dotson, PE
of a
second
but
the
error
tried
> > doing wrong.
It was stating that if you want this (2nd) constraint to be placed another
one needs to be deleted or edited. If you click on the red cross next to
the error message you will be presented with information on what constraint
is the problem and given a choice to edit or delete it (or cancel the
current constraint).
Constraint tracking has gotten better over the releases but it can still be
a bit tricky on a big assembly. Once you get more used to the environment
you can usually track them down pretty quick..
Also in the browser a yellow circle with an "i" in it means that there is an
error in a constraint.
Sean Dotson, PE
news:D27C1493C0CF0DE78A1AE5AFC5412163@in.WebX.maYIadrTaRb...
> them
> line
> then
> will
> > Sean Dotson, PE
> of a
> second
> but
> the
> error
> tried
> > > doing wrong.
