Inventor Forum
Cannot modify the library file
1 REPLY 1
137 Views, 1 Reply
I'm trying to edit a part that is in the Manufactured Parts folder.
But I don't get access to edit it.
I get this message < Cannot modify the library file >.
Is there some way to go around these problems?
Ulf Kolstad
Arctic Heating AS
1 REPLY 1
Inventor will not let you modify a part if the folder that the part is in is referenced as a library folder. You have 2 options, either copy the part to another folder, modify it , then copy it back or we've discovered that you can modify the part in the original folder if you make that folder the current project folder.
Hope this helps,
Mike
