Inventor will not let you modify a part if the folder that the part is in is referenced as a library folder. You have 2 options, either copy the part to another folder, modify it , then copy it back or we've discovered that you can modify the part in the original folder if you make that folder the current project folder.
Hope this helps,
Mike
