today i have faced a big problem - cannot launch any of Autodesk products. When i start Inventor i have that flash screen with loading bar for a couple of seconds and then it dissapears. Concerning other products (cfd, sim mech etc.) the flash screen does not appeat at all. Please help me out. I have installed ANSYS 15.0 yesterday - maybe that's a problem
Solved by stas87. Go to Solution.
Solved by cbenner. Go to Solution.
Need a lot more information. Which products are you using, what versions? Suite? Vault? System specs?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I'm using Autodesk Product Design Suite 2014 with SP1 on Inventor and also Simulation Mechanical 2014.
My specs are i7-2860QM, 16GB DDR3 1600MHz and Quadro 4000M. Couple of days ago everything was fine
