Hi
I have certain problems with Inventor 2011 and by Service Request I was advised to install the Service Pack 2 to correct program defects. But this requires deinstallation of Subsription Pack which really helps a lot. After the installation of SP2 program refuse to accept Subcription Pack and vice versa. Please advice how to install them both
Orest Yavtushenkoi
you have to install the sp2 for the subscription bonus pack: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16976209&linkID=9242019
DarrenP
Do I understand correct
Instead of installation of SP2 I should install the inventor_2011_subadvpk_sp2_x64 (90 846kB) ??
Then I could instal the Subscription Pack ?
Orest
I believe you will have to remove the regular SP2, install the subscription bonus pack, then install the SP2 for subcription bonus pack.
Yes in this sequence it works,
I mean SP1, Subscription Pack than SP2 Advantage (instead of regular SP2)
BUT
It does not treat the problem all this tricks with SP2 were made for.........
Orest
