INV2010 SP1, Advantage Pack, XP64 bit;
Can someone place this ANSI equal angle in an assembly and try to ground/unground it using RMB? I can 'Ground and Root Component', it can be grounded/ungrounded through the iProps, but there is no option to ground/unground using RMB. I have confirmed this behavior on three machines here. It's just the 'ANSI equal angle' that is affected, all other CC parts tested can be grounded using RMB.
I have edited CC parts by creating a part from CC, editing some iProps and then copying to family template. I have done this for all structural steel components, and this library is the only one that does this.
Any input is appreciated.
Edited by: matthewfitzmaurice7704 on Nov 18, 2009 5:51 PM
