I have just modelled a part with some faces and tried to convert to sheet metal to have inventor make the bends between the faces. However when trying to convert to sheet metal i get the following error message (Autodesk Inventor Professional Tip) - "This model cannot be converted to Sheet Metal because it contains features that have created multiple bodies. In order to convert to Sheet Metal these features must first be removed."
As the picture show the part only has 1 solid. Even when deleting all features except the "base" face I get the same error message or Tip as Inventor calls it. Does anyone know of a fix to this problem?
I have installed service pack 1.1.
Regards
Per Egil
I see multiple disnointed solids.
Once they are there - I don't think you can go back (unless you Undo back to where the first solid body was created).
Your best options are to use Derived Components or start over.
Is there a reason you didn't model this as a sheet metal part from the start? This would be easy with the sheet metal tools.
Thanks for the quick replies.
I have done similar things earlier but I might have converted the part to sheet metal before starting building the features. I tried moving the end of part over all the features and deleted everything except the sketches now and that seemed to work. After converting to sheet metal I could build the same features up again without any problems.
Why I didnt start with sheet metal and use the tools is that I prefer to model everything myself in sketches to have better control and easier adjustment later on.
You can "model everything myself in sketches" and still use sheetmetal tools such as the Face tool with the Bend option to create the part.
I use the bend command. I guess I could have used the face command as well since I do link the sheet thickness to a sketch dimension. I Just prefer the extrude to plane since then I`m sertain that the direction of the extrude correct.
"Derived Components" means...?
how to overcome this issue, please assist.
You could Combine the solids in one and try again.
Can you post the Ipt file? (i hope it will not be 2020 version)
@shaiju02yohannan wrote:how to overcome this issue, please assist.
Zip and Attach file here.
Hi! It should work. The part has as single solid body with disjoint lumps. Regardless, I don't see a reason why it fails to convert. Please share the file here.
Many thanks!
This was an old post.
The original image is from 7 yrs ago.
