Inventor General
Valued Contributor
ARCross
Message 1 of 17 (1,268 Views)
Cannot Create Custom Frame Member Part
1268 Views, 16 Replies
06-28-2010 12:14 PM
I created a template part, turned it into an I-part and published it successfully as a Frame Member.
The custom member was published into a custom library that is read/write.  I was forced to create this library in order to publish the part... I am not sure why.
When I go to use the custom profile with the frame generator, I am able to find the custom member in the dialog but when the frame generator tries to generate the part, I get this error message:
[WARNING] Frame Generator: Errors occurred during inserting Frame Member(s)
    [WARNING] Insertion of frame member(s) failed
        [ERROR] A frame member could not be created.  The template file for Unnamed GIRT-2 could not be located in the Content Center library.
Any thoughts as to where I am going wrong?  Thanks,
Andrew
*Pro
Dennis_Jeffrey
Message 2 of 17 (1,258 Views)
Re: Cannot Create Custom Frame Member Part
06-28-2010 01:55 PM in reply to: ARCross
Inventor version please?
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
Valued Contributor
ARCross
Message 3 of 17 (1,255 Views)
06-28-2010 02:20 PM in reply to: ARCross
Sorry, we are using InventorSeries 2010.
*Pro
Dennis_Jeffrey
Message 4 of 17 (1,252 Views)
06-28-2010 02:26 PM in reply to: ARCross
Did you author it as a structural part?
Can you zip and attach the original pre-published part? I'll take a look
whunter
Message 5 of 17 (1,214 Views)
06-30-2010 01:27 AM in reply to: Dennis_Jeffrey
Hi all;
I get the same error. Inventor 2011, 64-bit. I've attached my 'authoring' file. Any ideas what's going on here? I've done this before and then it worked, must be doing something wrong this time round but I obviously don't know what.
William
*Pro
Dennis_Jeffrey
Message 6 of 17 (1,209 Views)
06-30-2010 04:38 AM in reply to: whunter
Question: What is this? See attached.
*Pro
Dennis_Jeffrey
Message 7 of 17 (1,206 Views)
06-30-2010 04:40 AM in reply to: Dennis_Jeffrey
Is this a custom notch shape?
whunter
Message 8 of 17 (1,201 Views)
06-30-2010 04:50 AM in reply to: Dennis_Jeffrey
Yes.
Background: I'm evaluating if we can use Inventor for our designs (currently using Bentley ProSteel with AutoCAD), the only thing stopping us is the ability to model structural end connections with coping/bolting/plating. I thought of using Revit, but we also do a lot of mechanical work, more than structural, on the same projects (typical of modular mining plants), so...
The only option I see is a combination of custom notches and iFeatures and/or iCopies. There's the API too, of course, but that's a lot of work/time.
wh
*Pro
Dennis_Jeffrey
Message 9 of 17 (1,200 Views)
06-30-2010 05:02 AM in reply to: whunter
This part ( made from your sketch) works. Check the table differences.
Note that I did nothing with file naming or descriptions.  Fix your part first, then work on those. Resources on Content Center descriptions, etc. are available in the March/April issue of The Creative Inventor Magazine.
You might want to review this document:
http://teknigroup.com/AU2008
I'll be back at AU this year with an enhanced version of this subject.
Valued Contributor
ARCross
Message 10 of 17 (1,182 Views)
06-30-2010 08:27 AM in reply to: ARCross
Sorry for the delay in getting back to you.  I think part of our problem was a faulty installation of Excel.
I also redid the part -  a custom girt.  Here was my workflow:
1.Create profile sketch:
2. Extrude sketch - use a parameter labelled 'length'
3. Turn part into an i-part - create table that allows for multiple widths of girt.
4. publish as a structural member - in the parameter mapping dialog - enter 'LENGTH' for the 'BASE LENGTH' box.
5. Publish
I had to create a read/write library under the edit projects dialog box - far bottom right corner, click libraries button and create new library.
Anyway, it seems to be work now although I need to do some more work in order to get the part showing with necesary information in the BOM.
AC
PS - I have been working on the part on a new computer that doesn't have interenet set up. Otherwise I would post the post the part for critique.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
