I need to tolerance a fractional dimension using fractions in the tolerance box. For example: 3/8" +0 -1/32".
Can this be done within the style editior or does it need to be added as text?
Solved by Daren.Lawrence. Go to Solution.
This can be done using a fractional style and then you can edit the dimension and add your deviation tolerance. See attached images.
Please mark this as resolved if it answers your questions. Thank you.
Better still: Just apply your deviation to your dimension style - so you'd use 1/32 precision and it will display +0 / - 1/32
Thanks, that worked great. I just had to go into the Styles Editor and change the size of the tolerance text so that it would match the size of the dimension text.
