I tried and tried then went back to the example that worked and realized
that it hadn't worked, sorry for the false hopes. I'll go clean the egg off
my face now.
K
"Sean Dotson" wrote in message
news:1D9C376ED408215F8534742E437084DC@in.WebX.maYIadrTaRb...
> Thanks for the tip on #1. I'll file that one away.
> If you figure out how to get the second part to work be sure to let me
know.
> I've tried many ways before but could never get it to work...
> Sean Dotson, PE
> http://www.sdotson.com
> ...sleep is for the weak..
> "Karl Maas" wrote in message
> news:09212D3FC152B4571B48E12D3973C5CD@in.WebX.maYIadrTaRb...
> > for starters, instead of your step #1 you can RMB on the folder heading
> and
> > select delete folder which will take all the params and make them User
> > params in one shot.
> > Secondly, I managed to accomplish what we're after, but alas, I can't
> > reproduce it. It had something to do with using the inserting an object
> from
> > the Insert pulldown before removing the link to the spreadsheet. The
> params
> > somehow magically jumped from the referencing the link to referencing
the
> > embed. I'll see if I can figure it out.
> > K
> > news:15D54F6216F6FB8E352D100FE8FBD4FF@in.WebX.maYIadrTaRb...
> > > The only way I know to do this is long and nasty:
> > > 1. RMB on each param in the params menu and choose Add to user
params.
> > > They will be moved to user params
> > > 2. After each one has been added then RMB on the excel sheet in the
> > browser
> > > and delete
> > > 3. Change each of the user param names to something else (e.g. length
> to
> > > length2)
> > > 4. Reinsert the Excel sheet and embed
> > > 5. In the params menu make the value of the user params length2 for
> > example
> > > = to the name of the embedded param (e.g. length2=length)
> > > I told you it was nasty. If anyone has a better suggestion I'm all
> > ears...
> > > Sean Dotson, PE
> > > "Lester Martin" wrote in message
> > > news:02FC90FC9C0B200616F8ABE85D62F93D@in.WebX.maYIadrTaRb...
> > > > I have a part which is linked to an excel spread sheet. Now I would
> like
> > > > that spread sheet embedded. Is that possible?
> > > > Lester Martin
