Inventor General
Valued Contributor
Message 1 of 4 (220 Views)
Can you convert an idw file to a vsd file "Visio"
220 Views, 3 Replies
01-25-2013 06:46 AM
I am working with a few engineers and they want me to convert the idw drawing file to a vsd "Visio" file for there redline process. They would like to be able to play with the line work in Visio. Is this possible?
IV 2012 Pro-Suite / VP 2011
Windows Vista Enterprise - 64 Bit
Precision Workstation T7500
Intel (R) Xeon (R) CPU - E5504 @ 2.00 GHz (8 CPUs)
12284 Mb Ram
Dual Quadro FX 5800
Lance_White
Message 2 of 4 (218 Views)
Re: Can you convert an idw file to a vsd file "Visio"
01-25-2013 06:48 AM in reply to: Calavetta123
No idea with Visio but my guess would be no they can't alter line work if you can get it to the correct format.
Have they looked at Design Review for doing the markups?
Lance W.
Inventor Pro 2013 (PDS Ultimate)
Vault Pro 2013
Windows 7 64
Xeon 2.4 Ghz 12GB
Valued Contributor
Message 3 of 4 (212 Views)
01-25-2013 06:56 AM in reply to: Lance_White
They do use Design Review but you are not able to edit the actual line work. You can only redline the drawing and then the drafters have to make the actual changes. They want to be able to make changes in Visio with the line work so then when the drafters are given the redlined drawings they will know exactly what the final product should look like instead of seeing a bunch of stuff crossed out and other things added. It sometimes can get a bit messy when they start doing total design changes off of existing drawings.
Robert
12284 Mb Ram
Dual Quadro FX 5800
New Member
Message 4 of 4 (183 Views)
01-26-2013 04:10 AM in reply to: Calavetta123
Perhaps one option may be to convert the IDW to an Autocad "DWG" file. The engineers can markup the DWG as well as add new lines as required without losing the integrity and traceability of the original drawing. Best though to do new line work on a new layer!
If the engineers do not have Autocad to do this they can use Draftsight instead (its free!).
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
