Inventor Forum
Can you change constraint highlight colors?
9 REPLIES 9
Message 1 of 10
SharkDesign
3697 Views, 9 Replies
Is it possible to change the colours that the constraint tool uses to highlight the parts you have selected?
It's currently set to green and red but I use a lot of green parts so it doesn't really help.
  Expert Elite
  Inventor Certified Professional
9 REPLIES 9
Message 2 of 10
harco
in reply to: SharkDesign
I think it may change when you select a different background colour.
Otherwise there may be a setting in applications options.
Message 3 of 10
dave_deane
I think you can do this if you install the Color Scheme Editor. It is located in the SDK folder in Program Files. Here is a snapshot of the editor and the folder it is located in.
http://screencast.com/t/bZDVyz1f
Dave
Message 4 of 10
SharkDesign
Thanks!
James
  Expert Elite
Message 5 of 10
SharkDesign
in reply to: dave_deane
It doesn't work.
I dunno if maybe it's not allowed to access the registry or something.
  Expert Elite
Message 6 of 10
dave_deane
You definitely will need admin rights since the program will modify the registry. I have used it and it works for me but I am also an admin on my machine at work.
Dave
Message 7 of 10
SharkDesign
I've definitely modified the registry before, but I can't remember if that was before I got my new machine, so maybe it's changed.
  Expert Elite
Message 8 of 10
dave_deane
You can verify by checking user accounts in Control Panel
http://screencast.com/t/idWmhq6jabwv
Message 9 of 10
SharkDesign
I checked and I am an admin. On the colour editor I click save and nothing happens.
I've tried it with Inventor open and Inventor closed.
  Expert Elite
Message 10 of 10
Oesh01
Look into using Inventor Color Scheme Editor found in the "User Tools"
You might have to run the "UserTools.msi" to populate the "User Tools folder... once you have the "User Tools" folder availible browse it, then "ColorSchemeEditor" folder, then "Bin" folder... in there you will find the "InventorColorSchemeEditor.exe".  Run it.
Windows 7 users can find here: C:\Users\Public\Documents\Autodesk\Inventor 2014\SDK
