I created a sub with in a sub that I exploded on the part list & discusovered I need to consecutively re-order the child (X.XX) numbers but I cannot figure out how.
In the part list below I'd like to re-order the 1.30, 1.31, 1.32 etc. I got in this predicament because I had manually changed the 1.XX to match the description number (highlighted).
Using the reorder button will just remove the .XX's. Clicking on the + symbol next to the subasy will collapase the 1.XX numbers so I can use the re-order button but exposing them again they are still in the wrong consecutive order.
Gary
Solved by gcross. Go to Solution.
I figured it out.
All I had to do was select the specific lines while editing the part list & do a sort. Then it sorts just the lines selected...duh, I shoud've know it would be that easy.
Thanks Don for replying via email.
Gary
