I doubt you can do it in Sheetmetal and unfold it without some
workarounds. I think I would try making it without the grove part and
then derive it into a new file, and make the cuts there. You can then
make a flat pattern of the original, and use the derive for the rest of
the views. You could also make the cuts in the original, and fill them
in the derive and use the derive to make the flat pattern.
Kent Keller
http://www.KWiKMcad.com
Autodesk Discussion Group Facilitator
"stefanw" wrote in message
news:40fd19ea_3@newsprd01...
> Hi All
> I have modelled the attached. and need to produce it in flat form.
> Where I have problems is with the cut groove in the material for the
bends.
> There is a good reason for doing it this way.
> The material is High Density Polyethylene 1/2" thick formed by hand to
fit
> other components.
> Bending the material at full thickness is impossible so the groove
feature
> is added to help the material form.
> Any suggestions
> Thanks
> Stefan
