Inventor Forum
Can't save to Style Library
4 REPLIES 4
avi120
2862 Views, 4 Replies
Can sameone help about this
4 REPLIES 4
cwhetten
in reply to: avi120
The image you posted shows the steps for updating FROM the styles library, which is the opposite of saving to the styles library.  You have to select the option to save to the styles library (shown below):
If this command is not available, then your project file probably has the styles library set to read-only status.  You will need to change this:
-cwhetten
Please click "Accept as Solution" if this response answers your question.
avi120
in reply to: cwhetten
Thank You.
ed.bolz
Your screen shot shows that the 'Yes' is greyed out - which is the same case for me - how do I get that to be an option?
salariua
in reply to: ed.bolz
Make sure that the project file is not read only (right click on explorer), that is not vaulted (checked in) and that you only have it open on one Inventor session. Others need to close that project if it's on a shared network drive.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
