I have an adaptive part which I created within an assembly. I created work planes in this file, based on features in the assembly, and created a sketch on one of these work planes. I used this sketch for an extrusion. then I wanted to reuse the sketch again for another extrusion - normally one needs to select 'Share sketch' from the right-click menu of the sketch, but this is not available. I have already experienced this (random) behaviour, i.e. the 'Share sketch' option missing from the menu. In those case it was ok to make the sketch visible, and then I could use it again. But now it doesn't help. I made it visible, but when I click Extrusion, Inventor wants me to create a sketch, claiming there is no usable sketch. Why?
thank you
Daniel, Inventor 2013
Solved by johnsonshiue. Go to Solution.
Not true. Shared sketches appear in the browser at the same level as features (and unconsumed sketches), whereas non-shared sketches are consumed by features and don't appear in the browser until the consuming feature is expanded. Therefore, fewer items in the browser, which is what I meant by "less cluttered".
As for more planes... I don't think anybody in this thread from 2013 is suggesting creating additional planes, are they?
Sam B
Inventor Pro 2022.1.1 | Windows 10 Home 21H1
LinkedIn
