Or, try an insert with an offset at the bottom of the counterbore
Dennis
Dennis Jeffrey, Inventor 9/10 Professional user
Autodesk Inventor Certified Expert
Autodesk Product Consulting and Training
Omicron Electronics - Center for Design Excellence
http://www.omicronmi.com
http://www.design-excellence.com
260-312-6188
wrote in message news:4824397@discussion.autodesk.com...
Please see the attached file, IV7 will not allow me to select the
counterbore inside the yoke. I need to create an insert constraint between
the yoke and the cylinder asm shown, so that the cylinder asm can pivot.
The yoke is curved along the sides, facing inward slightly at the ends, but
the counterbore is parallel to the x-y plane and was created via a midplane
extrude. I tried to post the assembly but it was disallowed.
