Inventor Forum
Can't get components from content center
0 REPLIES 0
Message 1 of 1
BeKirra
218 Views, 0 Replies
I know that there is a simple solusion but can't figure it out.
We use vault for every projects.
I now create a "single user" project file without using vault for some drawings for someone else.
The folder is in my local drive and it is outside the vault working folder.
The problem I run into is everytime I click "place from content ceter" it asks me to login to vault.
BTW, my default content center locates in:
C:\Users\MyUserName\Documents\Inventor\Content Center Files\R2014\
Thanks for your help.
Updated:
I found the one:
Application Options => Content Center => select "Inventor Desktop Content" under "Access Options".
Is it the one-way solution?
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
0 REPLIES 0
