Inventor General
*Expert Elite*
karthur1
Message 1 of 3 (220 Views)
Accepted Solution
Can't edit section view properties
220 Views, 2 Replies
12-06-2011 07:13 AM
In my idw, when I right-click on my section view line (or the section view itself), I want to change the section depth from full to some distance.  Problem is there is not a "Edit Section Properties" in the context menu.
There are other section views on this sheet and they will display "Edit Section Properties" in the context menu.
Any clues as to why I dont get a context menu on just this one section view?  I could delete the view and redimension everything, but I had rather not.... Its got several dims on it.
Cant post the file either... its pretty large.?The idw itself is 16mb, not counting all the parts/assemblies.
Product Support
Message 2 of 3 (200 Views)
Re: Can't edit section view properties
12-07-2011 12:40 PM in reply to: karthur1
I can force a similar situation to occur of Defer Update is enabled in the idw, but this also has other more obvious hints that there is something preventing the section from being modified.
If you move/reposition the Section line sketch, does the view update? Does this change the behavior?
To properly diagnose, I'd really need a Pack & go of the idw. I can create a Support case for that if you'd prefer.
Dave Anderson
Premium Support Analyst – DLS Mechanical Design
Autodesk, Inc.
If I have answered your question, please "Accept Solution" so others may benefit as well.
*Expert Elite*
karthur1
Message 3 of 3 (190 Views)
12-07-2011 01:41 PM in reply to: dave.anderson
Moving the section line did not change the behavior and the view would update just fine. The defer updates was not active either.  I ended up just deleting the view and recreating the section.  Works fine now.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
