Hi Mike,
I'm using a 3Dlabs Wildcat VP 990 Pro video card. I went through the
configuration of the card with the reseller and it was found that I had the
wrong driver. That was before this current part was under development. The
driver I should have installed, per Autodesk's website where it got a rating
indicating that it passed all functionality tests, was the one previous to
the latest driver.
Anyway, what's with all this tweaking to get the program to perform the way
it should? I built my own system, so I guess that could be a basis for some
suggestion that this introduced difficiencies resulting in program
malfunctions, such as I'm experiencing. After having suffered through the
tech support of a prebuilt system by Micron PC, touted to be more than
capable of handling Autodesk's software, I simply don't buy that argument.
As for buying a comparable prebuilt system from, for example, Dell Computer,
I would have paid half again more for that, with no guarantee that I
wouldn't have had a similar experience from this integrator. I'm quite
happy with what I've put together. I would suggest that anybody that wants
to devote the required time into researching the parts they need to buy to
put one together to run Inventor do so. I got manuals, software, cables,
adapters, assembly instructions, etc, (all parts were retail versions) that
I never would have received with a pre-built system, not to mention the
excellent tech support and additional warranty periods from each device
manufacturer.
Concerning your comment about hiding visbility in the browser itself, that
was not the issue. The issue is hiding or showing the plane in the graphics
window. Apparently the only place I can do this is through the view menu.
The other places where I've been told by those that responded only seem to
function as indicators of the current visibility state, even though there is
a check box to change the visibility. Before I post this file I will need
to look more thoroughly through the program to see if there is some sort of
additional control that is preventing me from being able to change the
visibility in the graphics and browser windows.
Thanks to you and the others for the help so far on this issue.
Wally
"Mike Maenpaa" wrote in
message news:40fc1320_1@newsprd01...
> I have no problems turning WorkPlanes on/off in the browser or graphics
> area, or are you trying to hide visibility in the browser itself. You can
> click the funnel to hide certain items in the browser.
> What video card are you using?
> Mike
