I have one particular file which will not allow me to add an iLogic form. When I select "Add Form" it does nothing. This only happens in this one file. I can open other files in the same session and they work fine. I can add iLogic rules to this file but I can't create forms. Has anyone encountered this before?
Steve
Solved by MjDeck. Go to Solution.
I'm using Inventor 2013. Unfortunately I can't post the file because it contains proprietary information but in trying to strip out those details from the file I found the component creating the conflict.
This part file has quite a few derived sketch blocks from other parts. A particular one of these derived part links is creating the conflict. As soon as I break the link with that one component I can add a form, but as long as it is present (even if every other component is removed) the "Add Form" dialog will not trigger.
So now I know the location of the conflict, but I still have no idea of the cause.
Steve
I am experiencing this issue again with other files. There seems to be a bug with the iLogic Form Editor.
The symptoms are similar to before. If I break the link with the derived file then the iLogic Form Editor works but as long as the derived part's link is maintained I cannot trigger the Form Editor to create or edit a form. Interestingly enough I can create an empty form in the global Form Editor by right-clicking in the blank space and selecting Edit however I cannot add any buttons or load the form-specific Form Editor.
It is mildly frustrating.
Steve
Hi Tomas,
The iLogic rules seem to be corrupted. This is the first time I see a file like this. Let me work with the project team and see what can be done with it.
Many thanks!
Hi Tomas,
Thanks for reporting this.
There is a workaround. In the Parameters dialog, rename the parameter UP_Thickness to Plate_Thickness.
It looks like Plate_Thickness was the original name of the parameter, when it was connected to the Sheet Metal Defaults. If you launch the Sheet Metal Defaults dialog without renaming the parameter, the Thickness will be blank. But if you rename it to Plate_Thickness, then it will show up in the dialog.
@tomas_wiklund , I created an internal issue with number INVGEN-66859 for the problem you described.
I'm not sure if it's the same as what @ad64 was seeing.
