I need to constrain/mate the rounded nose of this plunger to the edge of the threaded hole in an already existing part. We are trying to retro fit a current design with a solution to a problem. I need these parts mated together so I can adjust the size of the plunger to fit into the current design. I have done a lot of searches through the discussion groups as well as online, but to no avail. I did read somewhere that you could use a tangent constraint between a curved face and an edge, but I can’t seem to be able to accomplish this. Anyone have any thoughts on how I could accomplish this?
Steven Ware
Autodesk Inventor Professional 2010 SB SP3
XP Pro SP3, 32-Bit, 3.00GB
NVIDIA Quadro FX 370
HP xw4600 Workstation
So,
what do you want to have happen with this?
Do you want it to be constrained (locked) in position or are you expecting Contact stop on motion?
OK, now I think I have it.
Do you have Inventor Professional with Environments>Dymamic Simulation?
Might help if I could speel.
Click on the Environments tab.
Do you see an icon for Dynamic Simulation like this
I guess I better show a "solution" without DS in addition to the DS solution.
