Inventor Forum
Can't Install Inventor 2014 or any other autodesk product
4 REPLIES 4
jorge10980
915 Views, 4 Replies
I was installing inventor but my computer ran out of battery and died. I used to have autocad but it stopped working too so I tried uninstalling everything like the forums suggest without success. I posted an image.
4 REPLIES 4
JDMather
in reply to: jorge10980
Did you try a Windows Restore Point?
Did you follow these instructions?
Clean uninstall.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Clean Install
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17955581&linkID=9240617
The CADWhisperer YouTube Channel
Cadmanto
Welcome to the forum.
I am with JD in that you need to completly remove any autodesk product before you even excercise the thought of starting to reinstall Inventor or Autocad.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
jorge10980
in reply to: JDMather
I already tried uninstalling using CCleaner and regedit to remove it from the registry and then installed it again but I got the same thing again.
JDMather
Restore your computer to original out-of-box state.
Install all Windows Updates.
Install Microsoft office and run Excel once.
Create a Restore Point.
Install Autodesk products (using recommended proceedure).
Tip: I always create a Windows Restore Point before and after installing any software.
