I was installing inventor but my computer ran out of battery and died. I used to have autocad but it stopped working too so I tried uninstalling everything like the forums suggest without success. I posted an image.
Did you try a Windows Restore Point?
Did you follow these instructions?
Clean uninstall.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Clean Install
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17955581&linkID=9240617
Welcome to the forum.
I am with JD in that you need to completly remove any autodesk product before you even excercise the thought of starting to reinstall Inventor or Autocad.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Restore your computer to original out-of-box state.
Install all Windows Updates.
Install Microsoft office and run Excel once.
Create a Restore Point.
Install Autodesk products (using recommended proceedure).
Tip: I always create a Windows Restore Point before and after installing any software.
